Trenching what tool?
daniel
10-01-2000 18:56:51
i have read a lot of posts on trenching using middle busters subsoilers and plows. i have a 971 ford with a 3 point. i do not own any type of plow or disc to start with so if you guys had to go out and buy a tool to bury water pipe and conduit in sandy soil with some stones what would you get? thanx dan
Dave M
10-02-2000 07:26:23
 Re: trenching what tool? in reply to daniel, 10-01-2000 18:56:51
How deep do you have to go? Does your ground freeze in the winter? Water line must go below the frost line. A middlebuster might be able to trench 18" deep, but probably not in one pass.
dan from mi
10-02-2000 09:52:21
 Re: Re: trenching what tool? in reply to Dave M, 10-02-2000 07:26:23
18" would be plenty. yes in michigan you can count on lots of frost but i plan on draining the pipe in the fall. does the middlebuster provide for the deepest trench compared to the subsoiler?
Dave M
10-02-2000 10:09:20
 Re: Re: Re: trenching what tool? in reply to dan from mi, 10-02-2000 09:52:21
A subsoiler can generally dig deeper than a middlebuster because its profile is smaller, but it is just going to loosen the dirt. The middlebuster probably won't produce a real clean trench, but it will clean it a lot better than a subsoiler. I have a combination subsoiler and middlebuster with different bolt-on shanks that works OK. Soil type and moisture will determine how well it will do. I once tried to make a trench when the soil was too wet, and the wheel ruts were as deep as the middlebuster trench.
Good luck.
dan from mi
10-02-2000 10:15:03
 Re: Re: Re: Re: trenching what tool? in reply to Dave M, 10-02-2000 10:09:20
thanx for the info!
Trapper
10-02-2000 10:52:33
 Re: Re: Re: Re: Re: trenching what tool? in reply to dan from mi, 10-02-2000 10:15:03
Dan, I've never done it but my buddy swears by his landpride rear blade for trenching.
He tilts and angles it and has at it.
charlie
10-02-2000 16:30:57
 Re: Re: Re: Re: Re: Re: trenching what tool? in reply to Trapper, 10-02-2000 10:52:33
i've buried several water lines with a sub soiler.cooper is a little tuff,but for plastic i bought a cable puller9looks like chinese hand cuffs)and mounted it on the bottom of the shank.it works real well.good luck
