JD baler operation
Doug
09-29-2000 08:44:22
Is there a problem with running a square baler dry? Just bought the baler and having never operated one I wanted to watch the thing cycle without actually baling anything. Is this bad or hard on the baler to run it without anything going through it? Thanks for your help.
Duane
09-29-2000 18:10:18
 Re: JD baler operation in reply to Doug, 09-29-2000 08:44:22
My JD Book says not to trip the knotter without twine in the needles, unless all you're doing is turning through by hand.
ErnieD
09-29-2000 16:13:22
I assume by "running dry" you mean without hay. You can do that for a long long time. If you mean by manually tripping the knotters and tying, just one cycle then you need hay or straw to clear the knotters.
Make sure your guards are in place, kids are not around and no loose clothing to get drawn into the works. After you use it for awhile you will lose your fear of the machine and become comfortable. Watch out, this is when people get hurt.
I heard of a farmer who finished milking and went to the field to check on his wife who was baling. She had gotten caught and drug into the machine.
