Old disk
kent
09-21-2000 19:28:31
I have just bought an old disk and come to find out it has no identification castings on it. It has part numbers casted into it but nothing that says the make. It is about seven feet wide and has two handles to adjust the angle of the cut. It also has two handles to move what looks to be a cleaner for the coulters back and forth. The bearings are made of wood and are fed with grease through gravity tubes. It hase no wheels and was originaly a horse drawn unit, so says the original owner. any thoughts are appreciated,thanks
AGEN
09-22-2000 14:06:29
 Re: old disk in reply to kent, 09-21-2000 19:28:31
I just happened to run across this after reading your question. DOes it look like this? Hope it helps. (I have no idea what it might be, but it looked like your discription)
