It worked!
Kermit
09-19-2000 17:32:07
Just had a fence row bulldozed in preparation for a new fence. I had four post holes to dig so I could set the corner posts. We live in SW MO, and it's VERY dry here. No rain in August, and so far only 1.3" in September. I just purchased a new Bush Hog model 2102 post hole digger with the bear claw cutting edges. Everyone (including the dealer) told me I couldn't get the holes dug as it was too dry. Gave it a try and got them all dug. Got the auger down all the way to the gear box housing. I was really impressed with the new digger. Don't think my old Ford digger would have done it. The Bush Hog seems to be a great machine.
Hint on digging dry holes---Russ (NM)
09-21-2000 20:38:31
 Re: It worked! in reply to Kermit, 09-19-2000 17:32:07
I needed to dig some post holes inside my barn, which has hard packed dirt and really dry. I poked a small hole in the bottom of a large plastic jug and filled it with water. I set the jug where I wanted to dig a hole, and the next morning the leaking water had softened the dirt down about two feet. Much easier to dig.
Kermit
09-22-2000 02:57:51
 Re: Re: It worked! in reply to Hint on digging dry holes---Russ (NM), 09-21-2000 20:38:31
Kind of a similar to this thought was an instance when I needed to drive a copper rod into the ground to use with an electric fencer. To be able to drive in into the ground and get it to actually make a ground due to the dry conditions I soaked the ground with water. It worked very well and I got the fencer operating properly.
Very good idea
09-22-2000 01:08:18
Dave in Mo
09-20-2000 19:45:03
Kermit, you must live down by Branson/Springfield so it's got to be fairly hilly and rocky too. Did you have any problems with rocks?
Kermit
09-20-2000 23:51:48
 Re: Re: It worked! in reply to Dave in Mo, 09-20-2000 19:45:03
We live southwest of Springfield. Only had trouble with rocks in one hole. Churned out a few good size ones. I was really impressed with how easy the auger dug the holes. The auger steadily worked it's way down, and I got all the holes clear to the gear box housing. I also like the way the Bush Hog mounts better than I did my old Ford.
