JD 350A rake
Thomas
09-16-2000 06:57:05
Does any one know if this would be a suitable rake. It is a 4 bar with both a 3 point hook up and a pull carriage. It has 2 smaller rubber wheels on the back only.
Farmer Tom
09-16-2000 20:09:45
 Re: JD 350A rake in reply to Thomas, 09-16-2000 06:57:05
I have a 3-point JD350 rake and use it behind my JD3020. I find that it works real good; just recently finished using it on my second cutting. I have also used it with my JD60 and it worked okay too. I haven't had any trouble on the corners; just got to go the right way!
Fudd
09-16-2000 07:04:20
Hi again. I have one and it works great. I don't like the 3 point part of it because of how it does the corners. It tends to miss a lot of hay when you turn a corner compared to a wheel rake. Not only that but if you lift it off the ground it is heavy and you need a heavy tractor to do that.
