Massey-Harris 5-6 foot hay mower
Mike McIntyre
09-10-2000 16:47:10
We have an old Massey(steel wheels, originally horse drawn) hay mower. We are really struggling to get it to cut properly.
We have replaced worn knives, the knives have been filed until you could shave with them, we have set the Pitman so that the knives centre on the guards.
We are pulling the mower behind a Ford 8N and it simply doesn't cut properly.
Any advice on additional things we might try would be very much appreciated.
Thanks in advance
Mike
Tom from Ontario
09-16-2000 18:36:43
 Re: Massey-Harris 5-6 foot hay mower in reply to Mike McIntyre, 09-10-2000 16:47:10
Sounds frustrating. I'm just guessing and I think you taken a lot of good steps, but which way did you file or grind the sections? Remember they must act like scissors and two flat surfaces must meet at the cutting zone. If the top surface of the guard or the bottom surface of the knife have the edge worn or ground away, this is like trying to cut with scissors where the blades are a distance apart. Also depends on what you are trying to cut. If it is common hay or alfalfa, serrated sections will likely last longer and cut better than smooth. The first time I used a hay mower, it had smooth sections, I carried 5 knives with me, changed them every hour and spent my lunch hour and after supper putting an edge back on them for the next run. With serrated sections in a swather, I put them on new and run them till they break. Hope you get better results. Good Luck.
