New Idea 323 Picker
PoppinJohnny
09-04-2000 08:38:19
I got it home. Yes it is in prestine original condition. When I put it on the PTO, it made regular corn picker noises. The the slip clutch on the wagon elevator was slipping. Ofcourse, it stopped when I pulled the rope. I opened the door on the bottom of it, and came out straw, mouse nests, ect, but nothing that would make it slip. I checked it out real good. Should I go ahead and adjust the slip clutch?
paul
09-04-2000 17:35:34
 Re: New Idea 323 Picker in reply to PoppinJohnny, 09-04-2000 08:38:19
Shouldn't take much to make an empty elevator go, I'd check it out very closely before upping the slip clutch. can you get it moving forward or reverse by hand?
--->Paul
Tim(nj)
09-04-2000 15:05:16
Mine gets a bird nest in it every year, even though it's in a shed. Check behind the chain. Sometimes wadded up straw will get in there and jams between the chain and the sprocket, slipping the clutch. Also look at the sprocket up top, making sure there's nothing stuck under that chain.
