Slip clutch on Ford brush hog
Sue
08-28-2000 07:04:07
I need information on maintaining the slip clutch on a Ford (901 or 90I) 60" brush hog. Where can I get a manual? The problem I am currently having is the slip clutch is "slipping" all the time. I am mowing mostly tall grass with the occasional volunteer sapplings. Even on flat areas with only tall grass the clutch slips more often than not. Any ideas???
Thanks
raytractor
08-28-2000 21:31:00
 Re: slip clutch on Ford brush hog in reply to Sue , 08-28-2000 07:04:07
you didnt say how old your mower is, assuming it is several years old the springs that hold the slip clutch discs together could be worn out or the discs themselves may be worn due to past slipping. a slip clutch is suspose to slip when hitting a foreign object in order to protect the rest of the mowers components. your local ford/new holland dealer can order you an owners manual through their parts dept. you'll need to supply the model and component numbers off of the mower . good luck
