Ford 850 Hydraulic Repair Questions
martifm
08-03-2009 05:33:19
The fan belt was bad so... I disconnected/removed the flex coupler to pull the shaft forward away from the crank pulley. Great... I was able to install the new belt. Put everything back together and now the seal on the pump is leaking. I would like to remove the pump to have rebuilt. The resevoir is contained in the tubing of the front end loader. I will probably have to drain the resevoir? Once pump is rebuilt, do I have to bleed system? I am not familiar with hydraulics. Thank you, Fred
