Slip clutch maintenance
Skeeter
08-21-2000 07:25:55
Hello,
I just bought a heavy duty model 6' King Kutter brush hog. This model came with an 80hp gear
box and a slip clutch. This is the first cutter I've used with a clutch. The manual talks about
setting the tension on the clutch, but doesn't say much (anything?) about lubricating the clutch
plates. Several pervious posts have mentioned loosening the plates and putting grease or oil on
them and re-tensioning, is this the 'normal' accepted service? How does lubricating effect the
clutch tension requirements? Do the springs need to be tightened more to prevent excess
slipping? It would be helpful if someone (with experience) could post a good service procedure
for these clutches.
I got this unit new for $1000. Does this seem like a �good� price for a 6' HD unit w/ an 80hp slip
clutch box? Thanks Skeeter
Skeeter
08-22-2000 11:09:31
 Re: Slip clutch maintenance in reply to Skeeter, 08-21-2000 07:25:55
Thanks for the info guy's. It didn't seem like putting grease or oil on the plates made any sense. I'll do as suggested, loosen the plates, slip the clutch real good, and re-tighen as the book indicates. Thanks, Skeeter
RickB.
08-21-2000 16:04:04
If you grease or lube those plates in ANY way, you will wish you never bought a cutter with a slipclutch. Plate type slipclutches only require lubrication where the input shaft is piloted into the output side, and a grease fitting is usually provided for this purpose. FOLLLOW THE INSTRUCTIONS IN YOUR MANUAL. Why listen to a bunch of 'experts' when you have the correct info in front of you?
F14
08-21-2000 10:54:31
Price seems more than fair, from what I've heard about KK units.
I've never lubed my clutch, but I disassemble it every spring before running the equipment, and sand down the metal surfaces and clutch faces, clean everything up good and put it back together. This is only because it spends the winter outdoors, and the clutches rust up.
Setting the tension takes a bit of experimenting.
paul
08-21-2000 20:27:19
 Re: Re: Slip clutch maintenance in reply to F14, 08-21-2000 10:54:31
I wouldn't even bother with the sand paper - just loosen it, & let it slip a bit in spring, that will let it shine itself up, and not introduce wrong-way sand marks.
I'd say follow the manual too like the other fellow. But, DO pay attention to it, it needs to be able to slip, loosen it or take it apart or something every once in a while so it is loose.
--->Paul
F14
08-22-2000 03:52:52
 Re: Re: Re: Slip clutch maintenance in reply to paul, 08-21-2000 20:27:19
Yup, that'll work too.
About the manual: Real Men don't read instructions! ":^)
paul
08-22-2000 19:38:05
 Re: Re: Re: Re: Slip clutch maintenance in reply to F14, 08-22-2000 03:52:52
:) I hear you on the manuals... ;)
--->Paul
Burrhead
08-22-2000 10:35:40
That's a 10-4 on the "Real Men".
Research shows that 99.873% of all yuppies who study their manuals still can't answer their own question.
Bottled water and docker britches is what spoiled America's serene country side.
