Dave: We recently built a house on the surface of the moon - or at least the ground has enough rocks in/on it to look like the moon. I rented a trailer-type landscape rake thinking I could make short work of lawn prep. Basically the trailer type rake bounced over everything bigger than a softball. I probably carried 10,000+ rocks out of there by hand. They made a nice rock wall about 200 ft long. After all the big rocks were out the rented rake did an OK job - not great. Anyway, the rented rake did such a poor job I tried my hand at making a rake. It works at least as well (probably a bit better) as the rented rake - still not great. I have not learned to weld yet and my roots are in woodworking. I took an 8 ft piece of pressure treated 6x6 timber. Cut it into 2 @ 4 ft lengths and bolted them together making a piece 6 in x 12 in x 4 ft (nominal). Basically I wanted as much weight as I could get. I drilled 3/4 inch diameter holes every 3 inches into one of the timbers along a straight line. I then pounded 20 in length of #6 ree-bar (3/4 in) into each hole. This gave me the teeth. Then I just mounted it with box iron onto my '73 Cub. The hydraulics lifts the thing up and sets it down. I can change the angle of attack of the tines, but I kept it simple and did not create a method of angling the entire rake with regards to the tractor. I put cement block on top of the 6x12 to add more weight. It helps reduce the bouncing effect. All told I think I spent about $65. As a local farmer told me, removing rocks from fields is why you have kids. The entire family goes out and pitches in loading the rock onto a wagon. Good luck. Douglas Stockman Penfield, NY
