Missing wheel for IHC Corn Binder
Marty
01-27-1999 10:44:26
I am looking for any information about an IHC corn binder.
I also need a right hand side cast wheel. Thanks.
Norm
01-30-1999 02:40:31
 Re: Missing wheel for IHC Corn Binder in reply to Marty, 01-27-1999 10:44:26
If you are looking for the right hand wheel as you are setting on the machine, it is not really cast and there are two different wheels. The earlier binders had a lighter wheel than the newer binders, the bad thing is this wheel newer or older was not built strong enough for 60 years of use and are hard to find not bent up. If I have the wheel you need I would like$35 for the older one and $50 for the newer one (plus shipping) I have a lot of binders for parts but this is a hard find. If you are interested take an axle measurement and tell me whether your machine has oil cups or grease fittings.
Norm
717-543-5136
Norm
01-30-1999 02:38:52
Norm
717-543-5136
Marty
02-02-1999 06:36:31
 Re: Re: Missing wheel for IHC Corn Binder in reply to Norm, 01-30-1999 02:38:52
I looked last night. I did not see any type of grease fitings. The left side wheel had a hole in forging that was plugged with a stick. The left side wheel seems to be 36" in diameter and is about 8 inches wide. I will try to measure the axle on the right hand side, if it would make a difference. The right side axle has a machined step and has a hole going through for a large holding pin or key. Thanks
Norm
02-09-1999 17:14:08
 Re: Re: Re: Missing wheel for IHC Corn Binder in reply to Marty, 02-02-1999 06:36:31
My e-mail is [email protected]
norm
Clinton E. Hofstetter
01-28-1999 12:25:58
I would check out some of the equipment recyclers in the amish communities in Wayne and Holmes counties in Ohio and also in Lancaster county in Pennsylvania. The amish are using these corn binders every year. I think that Small Farmers Journal out of Oregon has reprints of the owners manuals available. There may be other sources. In March, April and August there are machinery auctions in Kidron, OH that would have these machines there and many times parts or junker machines are also sold. Good luck
