VALBY THREE POINT CHIPPER?
Duane
08-02-2000 11:36:34
Anybody have any experience with these units? I'd like to find a good used one if they're any good.
james a. gregory
03-02-2002 18:35:52
 Re: VALBY THREE POINT CHIPPER? in reply to Duane, 08-02-2000 11:36:34
I have a nice one I may want to sell if you are still interested. They work great, but require a tractor with remote hydraulics.
Wardner
08-06-2000 07:51:14
I have a Valby 5" or 6" (can't remember) but do not use it very often. It does not have a power feed and it will cost me approximately $2000 to retrofit it. Power feed allows you to use a smaller tractor because it controls the feed rate. The feed rollers will also grab the brushy material and suck it in without any assistance from the operator. I use the Valby behind a 40 hp tractor. If it had a power feed, I could probably use a 20hp tractor and get the work done twice as fast.
F14
08-02-2000 15:02:42
I happen to have a PATU, but have used a Valby. Durn fine unit. As long as the outside looks good, about the only thing that can go wrong with them is the flywheel bearings or the knives. Be sure and size the unit to the tractor you'll be using to run it.
