Saw blade speed
ashley
07-30-2000 15:49:00
How fast should a saw blade on a firewood saw bench spin
the saw I have is about 32" diameter the correct speed of any diameter will do as I can then work out the tip speed needed for my saw
thankyou
to reply directly remove # from email address
Mike
08-03-2000 09:46:05
 Re: saw blade speed in reply to ashley, 07-30-2000 15:49:00
I am looking into buying a circular sawmill. Spoke to a guy at Foley-Belsaw, he indicated that a 46" saw blade should turn at 500-600 rpm to cut properly. Don't know it it is different for fire wood. Their number is 800-942-4406
Duke
08-01-2000 20:21:12
My saw is about 32". The driven pulley is about 1/2 the size of my belt pully (A JD) I saw at about 800 engine RPM so the saw is turning 1600 RPM. I haven't measured any of this it is all estimated. Didn't cut any fire wood last winter so this is all memory.
PS I suffer from CRS
