KING KUTTER AIR IN LIFT SYSTEM
ed
07-18-2000 08:34:00
HI FOLKS, HAVE A KING KUTTER WITH HYD.LIFT. QUESTION IS I NEED TO CHANGE THE HYD. HOSES WHEN I DO THIS I AM SURE THAT I WILL LOSE SOME FLUID WHAT IS THE BEST WAY TO BLEED THE SYSTEM OFF AFTER I REFILL . THERE APPEARS TO BE SOME ALLEN SCREWS ON THE HYD CYC. I WANDER ING IF THESES WERE THE BLEEDERS. THANKS ED
Dan form PA
07-18-2000 13:54:37
 Re: KING KUTTER AIR IN LIFT SYSTEM in reply to ed, 07-18-2000 08:34:00
You don't need to bleed remote hydraulic systems (except in certain unusual cirumstances), the air will work itself out. What little may be left won't hurt. Like larry said, just cycle everything through a few times.
Also, posts are much easier to read with proper use of caps. All caps makes you sound as if you're shouting. :)
Andy
07-22-2000 05:49:47
 Re: Re: KING KUTTER AIR IN LIFT SYSTEM in reply to Dan form PA, 07-18-2000 13:54:37
Remote hydraulics, or any hyds, do not require bleeding. Prefill what you can, crank it, then gentlymove lift. Most all air will remove itself in the first few cycles. I have heard some hydraulic engineeers ask to prefill extra large cylinders, but I am not convinced its necessary. Hope this helps..... only exception might be closed loop constant pumps..
larry
07-18-2000 09:10:02
Hook it back to the tractor and cycle it up and down a few times. If it has a slave cylinder raise all the way up and hold then lower and hold lever in down for awhile.
