NH Crimper
any comments?
Jim H.
07-18-2000 08:00:17
I've got the chance to buy an old NH crimper - but I don't know anything about them. This is the kind with the all metal rollers - no rubber. I don't know a model number. The rollers look to be six or seven feet wide. Do they work? I guess the only thing I've ever heard about these type of things were bad, but that may have been comments about a "crusher", with rubber rollers, not a "crimper" with metal ones. These metal rollers seem to mesh like gear teeth. The guy only wants $75 for it. Help me out! Do I buy it or not? Thanks in advance. - Jim H.
ltf in nc
07-21-2000 10:12:26
 Re: NH Crimper - any comments? in reply to Jim H., 07-18-2000 08:00:17
Buy it. Buy a bunch of shear pins (bolts). Grease the machine and check it for obvious faults. Connect it to the tractor. Make a trial run at the shop by putting it in gear and verify all is well. Disconnect and go cut the hay. Immediately after cutting the hay reinstall the crimper. Put the tool box on the tractor and go back to the field. Do not wait for the hay to settle (read Pack) Set the height to where it is set a little high. Put the tractor in one gear lower than you mowed with. Engage and bring the PTO up to 540 RPM as you ease the clutch out and start crimping. When a shear pin breaks, stop and replace it and start again. You can get by with this implement and it can be used to benefit.
LB
07-18-2000 20:08:39
Around here the 402 and 404's in good shape bring $300-$400 at auctions. They are really hot items. Along with pitmanless mowers.
BFarr
07-18-2000 17:02:46
I ran on for years when that is all we had.
Needed more than 30 hp and an independent pto in order not to plug often.. I got very good at cutting out the plugs.
The bearing can be expensive on the machine. I found buying right from a bearing dealer was cheaper.
Although it did its job, I am glad it is parked on the stone wall. A good tedder does a good a job.,
Dan
07-18-2000 19:05:04
 Re: Re: NH Crimper - any comments? in reply to BFarr, 07-18-2000 17:02:46
I can second these comments. It worked well, but a tedder is better and faster and won't plug. I havent used one in at least 25 years.
If you get it, be sure and get a whole pocket full of shear bolts. You'll need them until you get the hang of what it will handle and what it won't. They're a safety feature, so get the right ones from the dealer. It will suck the hay off the ground from a pretty good height -- run it as high as you can and it worked better, as I remember.
B.C
07-18-2000 12:28:54
Use it right and it'll save a day in drying hay.
We use a Deere 31 which has a rubber roller against a smaller steel roller. It'll plug on stuff that's too coarse, tall or tough. But most of the time I think it's worth it. One of secrets is to condition the hay just as soon as you can after it's cut.
A mower conditioner is a much better idea. Let me know if you can find a decent one short of $1,500.
Tim(nj)
07-18-2000 19:30:09
 Re: Re: NH Crimper - any comments? in reply to B.C, 07-18-2000 12:28:54
B.C., if I get enough money selling the hay over the winter to buy that New Idea 5209 disk mo/co I've been looking at, I just may have a good JD 1209 to sell for $1500, . . . .but it's in New Jersey.
B.C
07-19-2000 05:37:56
 Re: Re: Re: NH Crimper - any comments? in reply to Tim(nj), 07-18-2000 19:30:09
Quite a long haul out to Ohio...if Carol Browner keeps insisting on RFG that would still push the price way to right of 1,500 delivered. But you take my point I'm sure reference putting up with an obsolete condtioner vs putting serious money into a MC for small acreage.
Burrhead
07-18-2000 11:28:13
About the biggest problem I ever saw when folks complained about the NH crimpers or crushers either one was poor operators and lack of maintenance performed on the machine.
If you keep the bearings adjusted right and keep grease in them they do ok, but they are not designed to crimp tree limbs or fence post. Some folks thought they should handle anything laying in the field and that kept breaking out the bearing casters and knocking out the shear pins.
You can get your money back if it don't work you can sell it for scrap iron for about $50 to $60.
