Need help with a NH 68 baler before I SET IT A FIRE
RATSKINNER
07-12-2000 12:29:00
I got this baler last year and I do have a poor copy of the owners manual.I have set the time by the way the book say to.But it still keep braking
off the shear bolts in the flywheel and the needle
cluch.I replace the shear bolts and then it will bale 40 to 50 bales then it will sear them all agin.I am starting to think that something is putting the needles in a binned and that it is not out of time. Now that I think about it it seem that the shear bolt on the needle cluch is braking frist and then the flywheel next.For it always brakes when the needle are up at the knotter.So was anybody had this problem before. I got 14 ac of wheat down on saturday and it took me a day sunday to get up 300 bales and the monday I got about 10 more bale .then the rain started so now the baler is in the barn.I have to keep telling my self Ilove to farm.
Ed S
07-17-2000 19:46:01
 Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to RATSKINNER, 07-12-2000 12:29:00
I have read all the answers to your problems,and I found my service manuel and all the answers match my book.The only thing that was passed over was about shearing the knotter drive bolts:(1)dirty knotter--clean knotters,(2)improper adjustment of knotter brake--adjust brake (3)too much end play in knotter stack--remove end play in knotter stack.To remove the end play on 66 and 68 balers you remove or add washers from under the retaining washer at the left end of the knotter shaft.All I can say is give it a try,it's hard to fix it without actually putting your hands on the machine.
B.C
07-12-2000 12:54:28
If you can do it I think you need to get a better copy of the owner's manual.
It sounds to me like it's out of time or the plunger stop is not working right. Also, there is a knotter disk brake up on the end of the knotter shaft. Sometimes the springs on that brake bust or get misadjusted. That brake is important. I fixed ours on our 68 about 1000 bales ago and it's not been a problem since.
I never had what you describe go on with our 68, except for the brake problem, but I had something like it go on with the NH66 that preceded it. Either knotter drive chain had broken or something and I had to retime it.
Good luck. Hope you whip it. Say hello to the New Holland dealer for me.
RATSKINNER
07-13-2000 12:40:21
 Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to B.C, 07-12-2000 12:54:28
i CLEANED IT OUT TODAY AND RAN IT THOUGHT ALL OF IT STEPES ADOUT 60 TIMES AND IT WORKED FINE AND EVEY THING SEEMED TO LOOK LIKE IT WAS WOKING OK.
SO THIS TELLES ME THAT IT IS NOT OUT OF TIME .SO SOMETHING IS PUTTING THE NEEDLE'S OR THE NOTTER IS A BIND .BUT ONLY WHEN THERE IS STRAW IN IT.
Burrhead
07-12-2000 15:41:21
When I looked in my NH crystal ball it says this.
Before you start trouble shooting check to be sure you have the right shear bolts and the lock nuts on them are tightened to 25 ft lbs of torque.
1. Dirty and/or binding knotters--clean and lube
2. Improper knotter brake adjustment- clean brake with brake cleaner and adjust, check to be sure pivot pins in brake linkage are'nt worn out.
3. Too much end play in knotter stack--add shims to remove excess end play.
4. Dull knives--sharpen and adjust
5. Worn knotter clutch gear-- check and replace as needed.
I don't know how much is too much wear on the knotter clutch. I have one here you can stick your index finger in the groove and it bales all day long with no problems. Also if the drive chains are loose any at all I would check my timing to be sure it did'nt jump a tooth.
Good luck and happy baling. B.C. is pretty sharp on these balers.
Duke
07-12-2000 20:22:13
 Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to Burrhead, 07-12-2000 15:41:21
It sounds like the needle brake is slipping and letting the knotter cycle when the plunger is not in the right position. The plunger stop is working or else your needles would be s shaped. What happens is you hit a rough spot in the field and the needle brake lets the tying cycle start, the plunger hits the plunger stop(which is raised into position by the needle frame), this shears the flywheel bolt. I am not sure what is causing the needle drive to shear , could be some thing holding up the needle movement ? Burrhead has some good suggestions.
Burrhead
07-14-2000 16:12:36
 Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to Duke, 07-12-2000 20:22:13
Yep that's what I think too, something is binding the knotters.
It could just be the bale density is set to tight and the knotters can't pull enough twine through to run a complete cycle.
The only other thing I've had to do that is the brass roller on the bill hook arm. If the brass had stuck and wears a flat spot on it when the knotters and needles get to that position it will knock out the shear bolts because the bill hooks can't open and spit out the knot.
Then maybe it will spin a little and not break them til it gets back to the worn spot again.
I would bet it's either the knotter brake or the bill hook arm brass rollers.
ratskinner
07-16-2000 09:22:55
 Re: Re: Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to Ed S , 07-15-2000 20:16:27
I run it throw all the stepes by hand and did not see nothing hitting and the bale chamber was just rebuld just befor I got it .but I will check it.
I don't know If this might be a clue to my problem.When the bale come out of the baler.You will get 5 or 6 that a even across the ends then you will get 2 or 3 that all not.I have justed it a dozen times and you think you got it right and them it goes back to the same old thing and one more thing the string on the left side keeps braking .Ethere on the wagon out right out of the baler.out of a 100 bales I will have 10 that will do that.
Ed S
07-16-2000 18:50:27
 Re: Re: Re: Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to ratskinner, 07-16-2000 09:22:55
Check the fingers on the cross feed they might be worn or broken(the tips on the fingers on a 68 had little hooks on them),in heavy hay they will deliver hay into the chamber evenly,but in light windrows of hay or slippery straw they won't.Check the adjustment on these fingers they might be to far to the left causing to much hay to be pushed into the left side of the chamber causing the bale to twist and break when it comes out of the chamber or break the twine at the knot.Move the fingers to the right about an inch at a time till it comes out even,also when you adjust the tension on the chamber tighten the right screw 2 or 3 turns tighter,this will compensate for the extra hay or straw in the left side of the chamber.You diden't say if the twine was broken at the knot,behind the knot,or if the twine was slipping off the bale still tied,if it is comming off still tied it's a good bet there is to much hay in the left side of the chamber,or the left tension screw is to tight.Setting the cross feed finger adjustment is a move it an inch or two and try it until you get a satisfactory adjustment,and one that works for hay might not work for straw.I also don't know what weight of twine you are using but the 68 baler works best with 9000 twine.Try this and get back to me this is off the top of my head I worked for a dealer that sold NH balers I am looking for my service manuel when I find it I might have better answers,my son borrowed it and if you have sons you know what I am talking about GOOD LUCK let me know!!!!! !!!!!
ratskinner
07-17-2000 08:12:53
 Re: Re: Re: Re: Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to Ed S, 07-16-2000 18:50:27
I will look at it .the twine is braking just behind the knott.the book said to bend the knife alittle so i did and the twine braking went down.but it still broke a few and you get some where the twine just comes off one side {unbroken}
I need to do something for I sold a load of straw on the wagon to a friend and out of 110 bales 30 were already broken on the wagon.
Burrhead
07-17-2000 18:42:40
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to ratskinner, 07-17-2000 08:12:53
I wish we knew about the breaking twine to start with.
If it's breaking behind the knot that means the bill hook is'nt releasing the twine.
You don't want the needle to drag when it is placing the twine, but it has to touch the knotter frame really really lightly.
Then you should have about 1/8" clearance between the needles and the twine disc. The twine disc is where the end of the twine stays caught when the needles go back down.
Now bend the knife arm up til it just rubs ever so lightly on the back of the billhook as it spins around. Be sure it don't bind on the billhook just be sure it touches lightly and scrubbs the back.
Completely loosen the bale density adjustments at the rear of the bale chute. Run a few bales through the normal cycle without tension to be sure everything is adjusted right.
ratskinner
07-18-2000 14:27:09
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to Burrhead, 07-17-2000 18:42:40
I was going to find it a new home .But I think I paid to much for it and I don't think that I could get my money back I paid 600$ for it is that to much.
I hate to say this but right after I bought it I saw one at a farm action go for 250$.
I grew up around wire bales.this is my first string baler.
Now that I am out on my own I could not afford a wire baler.But just the other day I was offered a JD 336 for 1000$.that's how things go.I keep hearing all these old farmer's around me saying that NH is the best baler a round.So far I have not seen it.so it looks like I am going to keep it for now.do you guy's now where that I can get a good hand book for it.I can get one from the local dealer for 50$.I should be able to find it somewhere cheaper.
I am going to take all the info you all have given me and try to work on it tomorrow.I will keep you posted on the out come. THANKS ALL.
Burrhead
07-18-2000 20:21:06
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to ratskinner, 07-18-2000 14:27:09
As for my part your welcome and all the info was from my manuals plus about 40 yrs running this mess.
When you get that knotter adjusted out right you'll be a lot happier. I don't know if you can order a manual from I&T for the balers or not.
I've had both brands thru the years and I would'nt trade a wore out NH for a new JD for my own personal use. The JD is foreign made too and they still want about $4500 more than a new comparable NH is going for.
The thing that hurts JD around here is the p*** poor dealers we have in this area. They have a poor service dept and they don't stock many parts. Any part you want for the Deere has to be ordered and then you wait and wait, and then still pay $18.00 extra on each item for expedited service.
Eed S
07-20-2000 19:53:06
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Need help with a NH 68 baler before I SET IT A FIRE in reply to Burrhead, 07-18-2000 20:21:06
Mr Ratskinner no thanks necessary always glad to help a fellow in need,and I have to agree with Burrhead that a wornout NH is still better than anything on the market.I'm a dyed in the wool IH man,but when it comes to balers NH WINS HANDS DOWN.Remember when you are making adjustments on balers only turn adjusting bolts a little at a time,move the fingers on the cross-feed 1/2 to 1 inch at a time,and don't over tighten the chains as this can change the adjustments.Good Luck and don't get discouraged.
