John deere 490 planter
ED
07-12-2000 06:35:16
hi. looking at a 490 planter question. does anyone know if this model had a hyd. lift the guy says it did but the john deere dealer said that this model was a manual lift . but could have been converted would anyone know what size hyd cylinder would fit this planter. and in fact if a cylinder would even work on this . thank you
pdxgreen
07-13-2000 23:12:10
 Re: john deere 490 planter in reply to ED, 07-12-2000 06:35:16
If you intend to use the planter, I would skip the 490, and find a 495. The 490 used gear boxes to adjust the ammount of seed planted, and the 495 could be had without the boxes, it used a series of sprokets and a chain to adjust the rate. I never had any problems with the 495 or my 895, but my neighbor had to work on his gear box from time to time. I planted far more acres than me did with fewer problems. As both machines are worth not much more than scrap price, I wouls hold out for one without the bearbox.
ED
07-15-2000 05:56:16
 Re: Re: john deere 490 planter in reply to pdxgreen, 07-13-2000 23:12:10
thanks for the info pdxgreen
Mike Aylward
07-13-2000 15:54:33
ED, if you're interested, I have a 490 that I would consider parting out, and it has hydraulic lift. Just let me know. Mike
MIKE
04-10-2001 17:51:34
 Re: Re: john deere 490 planter in reply to Mike Aylward, 07-13-2000 15:54:33
IF ANYONE HAS ANY 490 JOHN DEERE PARTS I MIGHT BE INTERESTED. MINE HAS MANUAL LIFT.
Karl in MD
07-12-2000 10:02:59
The 490 had a built in mechanical lift (somewhat like a plow clutch) The planter had to be in forward motion to lift or lower ( the latter to keep from plugging the shoes when it dropped). A hydraulic lift was optional and any 8" stroke ASAE cylinder will work. I had a 490, just watch for broken lift chains, otherwise a pretty good old planter (emphasis on old, they stopped making them in the mid 50s)
