Hay baling equipment
kenny mcdermitt
07-09-2000 09:30:19
I want to start baling some hay next season 12 - 15 acres and want to start as cheep as I can. I am not scared to use old equipment as long as it has been maintained. How much should a decent sickle mower, square baler and rake run me. What would you guys recommend and not recommend. Thanks in advance for any help.
Micheal
07-11-2000 14:55:59
 Re: hay baling equipment in reply to kenny mcdermitt, 07-09-2000 09:30:19
here in eastern ND, got a Ford 5-bar side rake for $60 (+ $50 in parts and teeth), a JD #11 trailer type mower for $200 (+ $25 in parts) and 2 - NH68 balers for $200 (one parts and one user). My brother got a NH Superhayliner67 for $165, no parts needed. All within the last 3 years. Just depends on your locale and how long you want to look. Auctions are sometimes good. Saw a super nice Ford 501 mower go for $435 (good buy), my dad saw a Case square baler go for $330 (a bad buy!) just my .02 worth.
micheal
B.C
07-11-2000 09:51:09
If my experience is any guide, a couple hundred bucks on either side of 500 should get you a usable baler. Stick to NH or Deere. They both work. Avoid NH wadboard types (66 or earlier).
A decent mower will probably run about 250 or so. Again stick with NH or Deere.
I never paid more than about 70 for a ground drive side rake. Expect to put about 10 or 15 bucks worth of teeth on it a year. If it's in any shape the make doesn't matter much but the old Deeres seem to hold up pretty well.
I use a Deere 31 conditioner but that's probably not a necessity. Saves a day worth of drying time most years. Junk to 250, depending on what you find.
Get the manuals and parts books on everything you can, and be sure to read them before using the stuff.
Joe
07-10-2000 12:30:53
I had the same problem, I have 20 acres and searched for 2 years and finally found some equipment I could afford, for all the advice I got, NH and JD are the better for balers. I got a JD 14t for $450 in decent shape, make sure you buy the "book" before you take it out in the field for any baler, make sure all rust etc. is out of the knotters and buy new string. Check the TIMMING!!!! My mower is a Massey Fergurson 31, that I paid $350, but then had to buy a new belt that cost $45 extra, but once I sharpened the teeth it worked very good, get one with a floating head, (belt driven) instead of a pitman arm, if you have any banks in your field. The rake JD older was the worst, I only paid $250, pulled out of the field and I know why, after I replaced $60 worth of teeth, I realised that somehow it was dropped and sometimes catches and stops the rake, it is ground driven, a lot of bangs with a sledge hammer straighten it out. but the baler is the most important, it doesnt do any good if you cut good and rake good, only to have your baler broke or not tieing and have you hay rot in the field. BUT, make sure you buy a book and check the timing and get plenty of shear pins. as to the differnences in the balers, the only problem with my 14t, is my windrows cannot be too big, as I hear the NH is better at, but around here Square balers people are pretty proud of them, but stick to the brand where you can get parts for, what does your local tractor deal supply. Good Luck
paul
07-09-2000 20:33:13
This has been discussed quite a bit of late, check the last 2 pages of messages! :)
It helps to know where you live if you want prices - dairy country, horse country, or heavy crop country will make a BIG difference on the prices of these things.
In general, older John Deere & New Holland balers seem to be good. Othere brands of 30-50 years ago had poor knotters, and you will probably have more problems than successes. But of course, these off-brand balers sell for scrap metal, so you decide. You'll want 35 hp and you will be much, much happier baling with a tractor with live pto. There are other options such as a baler with it's own engine, but 35-60 hp & live pto is the better option.
If you scrimp, scrimp on the siderake & mower. Get a good baler.
--->Paul
Fudd@Work
07-09-2000 22:38:31
 Re: Re: hay baling equipment in reply to paul, 07-09-2000 20:33:13
That's good advice Paul.
Karl in MD
07-10-2000 09:39:27
 Re: Re: Re: hay baling equipment in reply to Fudd@Work, 07-09-2000 22:38:31
Absolutely! You can get away with an old mower, and you can rake with just about anything, but the baler is critical. Get the best that you can afford.
