Sickle mower height range
SteveW
07-07-2000 06:18:39
What is the range of heights that can be cut with a typical sickle bar mower? I would like to cut an area at 8-10", but rotary mowers do a very poor job.
Burrhead
07-07-2000 15:14:43
 Re: sickle mower height range in reply to SteveW, 07-07-2000 06:18:39
Pick it up to where you want to cut. When you set the height then just set the bar to be level to the ground and at a 90 degree to the tractor. It will do fine.
I have to run mine off the ground because of the rough spots.
Bob
07-07-2000 17:35:10
 Re: Re: sickle mower height range in reply to Burrhead, 07-07-2000 15:14:43
INternational made gauge wheels for many of their mowers. one for the inside and one for the outside.
