Newholland 415 discbine
David
06-20-2000 14:27:55
i bought a new 415 in 1997 and have put 3 primary shafts in the last 4 years , the bolt that holds it in to the cutter bar keeps shearing .any one else having this problem ?the last shaft went to a machine shop and it was bored out to accept a oversized bolt . it seems to be holding up . i cant get new holland to make the parts and service right though .it cost me 473 bucks last time around new holand sux they wont stand behind there equipment .NOTHING RUNS LIKE A DEERE : (
RickB.
06-26-2000 14:31:58
 Re: newholland 415 discbine in reply to David, 06-20-2000 14:27:55
Overtorquing that bolt will fail it (due to stretching) right quick. Undertorquing it, or failing to use Loctite (or the correct OEM patch bolt) will cause it to back out over time. By now you should have the updated flex coupler just above that shaft. Is there any undue vibration coming from the cutterbar that is stressing the bolt?
David
06-26-2000 19:12:04
 Re: Re: newholland 415 discbine in reply to RickB., 06-26-2000 14:31:58
your very sharp the dealership said the newholland field rep said it was a loctite failure causing the bolt to back off and shear . but 3 times and in the last week in may each year
David
06-26-2000 19:00:26
i always let the local dealership perform the repair . as a custom baler i need the cutter back asap. ive ask the service manager if its operater error causing the failure he said that model is notorious for this problem .the dealership says its the manufacture the manufacture says it the dealership labor neither will pay for the repair .however the bolt looks rather small to me .(and its got the swivel hitch )there seems to be a slight vibration in the pto shaft that wasnt there new . its a late model after the serial number break and performs well under a load ( man it eats the hay up : ) and i dont want to spend the extra 6-8k for a deere but the dealership puts the combines first i always have to buy them a case of beer to get it in the shop.all i want is the manufacture to identify the problem and perform a upgrade to the primary shaft so all the operaters with this model will not be down all the time and have the unessacery expense .
RickB.
06-27-2000 16:14:27
 Re: Re: Re: newholland 415 discbine in reply to David, 06-26-2000 19:00:26
Good luck in your efforts. Please note the 1411 and 1431 use a completely different (better) drive to the bar. Customers of the dealership where I work have enjoyed great service from these models. Also, 411's don't seem to suffer the same troubles as much, could be the extra stress from the wider bar on the 415 is more than the primary shaft & its components can handle long-term.
Tim(nj)
06-20-2000 20:00:07
Last week, there was a discussion on what a piece of junk the Deere disk mo/co is at the following site. Click on machinery talk and scroll down aways. They may have gotten the search function up by now, too. (It's a fairly new site)
Tim(nj) couldn't find it today . . .
06-21-2000 19:09:17
 Re: Re: newholland 415 discbine in reply to Tim(nj), 06-20-2000 20:00:07
Didn't see the one about the Deere when I looked today, but there's still another gripe there about another New Holland.
