IH Plow Tailwheel Fell Off
halbert09
06-18-2000 18:14:42
I have an IH 3-pt plow with a steel rear furrow wheel. The wheel and the axle assembly it rotates on have fallen off. The axle assembly is bolted to a bracket which attaches thru the landside. The axle assembly bolts to the bracket with a thin hex nut(like an axle nut) which seems to be held in position and kept from unloosening by a 1" key or block of metal. The threads on the end of the axle assembly where the thin nut goes are stripped. Has anyone had this problem? What is the best way to get the wheel back on? Should I rethread the axle, look for a used one, or put the old nut on and tack weld it in place? Thanks.
Bob McCammon
06-20-2000 18:11:58
 Re: IH Plow Tailwheel Fell Off in reply to halbert09, 06-18-2000 18:14:42
You might just replace the furrow wheel with a long landslide on the bottom. I have done that several times.
Haybaler
06-19-2000 05:57:26
I would rethread if you use the plow. A replacement will be hard to find. Tack welding only causes Murphy to rear his ugly head. Good luck.HB
