J.d. 24t square baler
bgee
06-18-2000 11:05:33
Does anyone know how the pitman crank comes out of the crank case. Does whole crank case have to come out? Thanks
SCOTT
06-19-2000 18:41:40
 Re: j.d. 24t square baler in reply to bgee, 06-18-2000 11:05:33
I,M HAVE NO IDEA HOW IT COMES OUT BUT WOULD LOVE TO KNOW AS WELL. I AQUIRED A 24T LAST WEEK. IT APPEARS TO LEAK A LITTLE OIL AROUND THE CRANK. IF YOU FIND OUT I WOULD APPRECIATE ANY INFORMATION YOU FIND.
john-boy
06-21-2000 23:23:52
 Re: Re: j.d. 24t square baler in reply to SCOTT, 06-19-2000 18:41:40
Hey guys, These machines are approaching the 30 something age. If you are a custom baler, buy an op's and/or parts manuall(eBay has them all the time). If not, what does a bit of gear oil cost in your area? Call me a cynic if you wish, but I have grown up with these machines, and I can vouch for a cost vs. result effect.
bgee
06-22-2000 06:27:51
 Re: Re: Re: j.d. 24t square baler in reply to john-boy, 06-21-2000 23:23:52
The reason I asked this question is because my pitman crank is worn out, appx. .120" where the pitman shaft connects. I'm not a custom baler , only about 500 bales per year. Since original posting I have found that the best way is to remove the entire crank case and crank shaft together, am going to replace it with a used one that i found. To replace the oil seal You will need to remove the entire crank case less the input gear box, then remove the crank shaft to replace the seal, it's a big job.
SCOTT
06-19-2000 18:41:10
