JD sickle bars
Jim Ryan
06-16-2000 17:02:51
Can some one please explain the diferences between the JD #5 and #8 sickle bars I have one or the other and would like to know which one I have Thanks Jim Ca.
john-boy
06-19-2000 06:20:47
 Re: JD sickle bars in reply to Jim Ryan, 06-16-2000 17:02:51
The #5 has exposed slip clutch on the pto
driveline and the #8's do not, they are enclosed in the gearbox. As mentioned before, the 5's tailwheel more or less follows the right rear tractor wheel and the 8's tailwheel should follow the centerline of the tractor. I've run the #8 on many acres w/ satisfactory results
but many old timers say you can't beat the #5's.
ZiggyStardust
06-18-2000 18:03:21
Jim,
If the castor wheel is on the right side it's a #5. If the wheel is on the left side it's a # 8.
Tim W
06-18-2000 17:36:26
Jim, I have a # 8, but don't have a # 5. I do know that several of the parts are interchangeable, both are chain drive to the pitman. If you still have the serial # a J.D. dealer should be able to tell you.
Jim Ryan
06-19-2000 16:26:00
 Re: Re: JD sickle bars in reply to Tim W, 06-18-2000 17:36:26
Thanks a bunch guys its settled now, I have a JD #5 JPR
