Round baler vermeer 504f
Richard Lilly
06-16-2000 05:02:00
I'm having lots of trouble getting the bale started.The hay keeps getting pulled away from belts by the starting roller.Once the hay gets into belts it bales perfect.Does anyone know how to slow down the starting roller.Or may there be some updates for this thing? Help Please?
Peter Hansen
06-12-2006 09:59:39
 Re: round baler vermeer 504f in reply to Richard Lilly, 06-16-2000 05:02:00
Hi.
We had the same problem untill we noticed that the gearbox was set to 1000 rpms and our old tractor used 540 rpm.
After turning the gearbox upside down, it has worked ok.
Regards Peter
Doug Dailey
07-21-2004 06:06:52
I am also having the same problem with my 504G Vermeer baler usually when the hay is not fully cured. I have baled a lot more square bales than I wanted to in the last 2 years since I bought the baler. My square baler bales the same hay just fine and hay does not heat.
I have seen a suggestion on this web site that might work, that is to lower the RPM's when you start a bale and make sure you get the hay all across the chamber ASAP. If this doesn't work on my second cutting this year, I may have to sell it or give it away. On the plus side, I have built up a lot of strength in my back and arms pulling hay out of the machine.
Sid Miller
06-16-2000 06:50:32
My Vermeer does the same thing when the hay is to wet.
Richard
06-16-2000 08:45:15
 Re: Re: round baler vermeer 504f in reply to Sid Miller, 06-16-2000 06:50:32
It does this wet or dry.Seems to be worst if a lttle damp but it does this even dry.
