Round baler
Richard Lilly
06-14-2000 19:10:32
Started using a 504f vermeer round baler.What is the advantage to the wider belts on the sides? And which is better for locking the belt ends the covered #12 cable or solid covered wire?
Also how many wraps of string should be around each bale to keep it together and tight?
Round bales are sure alot more easy!!!!! !!!!! !
AD
06-14-2000 19:45:35
 Re: round baler in reply to Richard Lilly, 06-14-2000 19:10:32
Wider belts on outside help prevent them from rolling over. The narrow belts would turn over after they were worn and soft if the roll got started wrong on the ends.
Two or three wraps on the end and spiral it to the other end about 6-8 inches apart depending on size of grass.Closer if short grass and further if long stem. Then 2-5 wraps on the end,ever what it takes to keep it from unwinding when you drop it out. The less string you use the less it cost to bail but there is a point when to little causes problems. AD
