JD #10 sickle bar mower
Duane Hinds
06-11-2000 12:11:40
I am looking for a compatible mower for my JD 2020
There is a JD #10 side mount mower coming up at an auction. Would this fit my 2020? How much trouble is a side mount to hook up? What should I expect to pay? Any advice gladly accepted.
Jack C. Anderson
06-11-2000 15:35:37
 Re: JD #10 sickle bar mower in reply to Duane Hinds, 06-11-2000 12:11:40
Duane the No 10 in my opinion was a good mower. Side mounts are a more complicated to attach as compared to a drawbar model or 3 point. There are several advantages to a mid mount:
1. You can see it while driving
2. It goes where the tractor goes (doesn't slide like a trailing
3. compact
4. I believe the #10 will all good inclines to mow ditches.
THat's my 2 cents worth.
As far as value, I can't tell you $500 - $600 maybe?
Jack
rich davis
06-11-2000 18:32:46
 Re: Re: JD #10 sickle bar mower in reply to Jack C. Anderson, 06-11-2000 15:35:37
a #10 is a good mower I've used one for years. be sure the one you are looking at has the drive from a new generation tractor it would be a lot easier to have the correct drive setup than try and find one later. There were also two mounting plates make sure you have the correct one for a smaller tractor. If you want to give me a call I'll try and answer any questions. If it's in good shape and all the right parts value from 250-550 Rich Davis (540)463-6777
Duane Hinds
06-11-2000 20:18:37
 Re: Re: Re: JD #10 sickle bar mower in reply to rich davis, 06-11-2000 18:32:46
Thanks Jack and Rich for your insights. I suspect this particular #10 was used on a 720 as it is the smallest !! tractor in the auction. Atleast now I will know enough to look for the correct mid-PTO hook up. The 2020 mid PTO is 1000 rpm. Guess the drives were available for either 1000 (new gen) or 540?
