Rotory Cutter
DMan
06-10-2000 18:54:46
Dear Friends: I am contemplating purchasing what is advertised as a Ford 60" Rotory Cutter model #951A. My question would be could I expect comparable performence from a similarly sized "Brush Hog"
Could it handle heavy brush, up to 2" in diameter. Is $500 a reasonable price? Thanks
Joe
06-12-2000 13:12:35
 Re: Rotory Cutter in reply to DMan, 06-10-2000 18:54:46
I, too, am looking for a 5-foot rotary cutter. There don't seem to be many used ones for sale on the Palouse, and at auctions mostly are 6' and too big for my 8N (not to mention too spendy).
I just looked at a very faded blue Ford 5-footer that the implement dealer took on trade-in. He says the gearbox was rebuilt by his commpany 2 years ago, and it does turn very quietly & easily (and keep turning!) when I turned the PTO shaft by hand. No stumpjumper dish. He would take $675 cash, he says.
My other choices so far have been a new King Kutter for $750, and a new Howse for $640. Both of these look more lightly built than the old Ford, with the King Kutter being a bit heftier (especially in the skids on the sides).
My 20 acres is hilly grass/wheatfield, with no rocks I actually expect fairly light duty for this, once we get the grass established. So I have two questions: Are the Howse implements reasonably good? Or, would the old, rebuilt Ford be better than the new cutters - and worth haggling more with the dealer? - JOE
Aaron Hood
09-18-2001 18:51:16
 Re: Re: Rotory Cutter in reply to Joe, 06-12-2000 13:12:35
Old cutters are just that and if the gear box is good and all bearings seem sealed(not leaky). Go for it myself I've tried the used route, I don't have time to dicker around with equipment repairs when I need it for use I need it then. So my true aadvise is if you are a gambler and know the cutter is good buy it but remember your paying half the cost of a great cutter. That would be Bush-Hog and I don't reccomend anyone over that brand its proven itself over the years.
RWK in WI
06-11-2000 08:24:54
The Ford 951A is listed as a light duty model. It was available with either a straight blade or with a stump jumper center disk - much prefered, and also with a shear pin/bolt or slip clutch - prefered. The deck is 11 gauge. The chain guards are optional - they should be standard. It had a 40 HP gear box.
I have a 6' 953A - medium duty, slip clutch, stump jumper, and chain guards. I use it with a 45 HP Ford 3000 tractor and it can handle almost anyting the tractor drives over. Hope this helps you in your choice.
Dick Kraus
acmike
06-11-2000 04:50:10
I'm not familiar with that model number but I haven't seen Ford but their name on anything close to the quality built into the older style Bush Hog brand.
