Odd IHC side- mounted two-row cultivator
Plow Man
06-09-2000 15:05:37
I have this strange IHC side-mounted two-row cultivator for my Farmall H. It is something like the old 229. I don't think it is the HM-229, that was the update for the old 229. It is a two piece cultivator, not one. The rear part is just like the ones that were with the No. 461. It looks like it might have been made during the 40's to the 50's. It is similar to the 461, but the parts that hold the gangs on are made of cast iron. It uses 3 hydraulics, the old "Lift All" types. When You let the cultivator down there is a spring that helps it down. There are 4 square 1" by 1" bars. The one on the magneto side, closest to the tractor, the bar bends under the tractor. The two on the outside are straight then bend out at about 45 degrees. The other bar, on the exhaust side is straight. The shanks all have the spring trip option. Any ideas on what my cultivator model # is, please post a follow-up. Thanks.
paul
06-09-2000 21:00:21
 Re: Odd IHC side- mounted two-row cultivator in reply to Plow Man , 06-09-2000 15:05:37
Hummmm, got something like that gathering rust for the IHC 300. Mine is a 4 row, can take the outside 2 off & make a 2 row out of it.
--->Paul
