Mulching with a bush hog
Danny Yerks
06-02-2000 07:07:18
I was told that Bush Hog brand bush hogs have uplift blades and that if you run the mower with the rear lower than the front it will cut the grass multiple times, but if you run it with the rear higher than the front it will only cut the grass once and leave it in a pile to one side. This seems to make sense, but does it really make much of a difference? Also, is Bush Hog the only brand with uplift blades?
SCOTT
06-02-2000 11:17:26
 Re: Mulching with a bush hog in reply to Danny Yerks, 06-02-2000 07:07:18
Danny,
It is true that if you run the rear of the cutter lower than than the front it will mulch the material more. But BUSH HOG normaly recomends level or lower in the front. Running lower in the rear uses more h.p. Newer models have rear bands the allow for better discharge but older models still have fully enclosed rear bands.
BUSH HOG does offer uplift blades but not std. on all models. What model cutter do you have?
Danny Yerks
06-02-2000 11:56:57
 Re: Re: Mulching with a bush hog in reply to SCOTT, 06-02-2000 11:17:26
Scott,
I don't have one yet, I'm trying to decide what to get. I have about 3 acres of tall grass with some light brush that I want to mow. It hasn't been mowed in years, so right now it's real thick. Once I get it knocked down, I plan to mow it about once a month or so. As a far as mower quality goes, I don't need a real heavy duty one, since I won't put that many hours on it, so even a cheaper brand should last me a long time. I don't need a finished mowed look, but I also don't want the "rows" of thick grass that some bush hogs leave. I also don't want to spend more than $500. So, I'm trying to decide if I should just go buy a new King Kutter (Quality has them for $500) or get a used Woods, Bush Hog, or other heavier duty brand (I haven't found any used ones of those brands yet).
Mudcat49
06-03-2000 05:27:54
 Re: Re: Re: Mulching with a bush hog in reply to Danny Yerks, 06-02-2000 11:56:57
Danny;
I would hire someone with a heavy duty cutter to come in and cut it the first time. Have them cut it a couple of times, I custom mow and people have me do this all the time, as I use a heavy duty Rhino. After that iffen you are gonna mow it once a month then you can get by with a cheaper, lighter cutter.
Greg
06-02-2000 10:49:38
This true. With the rear higher than the front the Hog only cuts the grass once. This is easier on the implement. Mine does not leave all cuttings to one side but it is not a Bush Hog. With the rear higher, the front skids dig up the ground occaisionally especially if you have rolling terrain, so be careful if you are going across "lawn" or you will get a divit.
