NH 268 Small Square Baler
dave(ne)
06-01-2000 07:52:44
I bought this baler 2 years ago and have run about 3000 bales through it with very few problems. Now all of a sudden I can not keep the flywheel shear bolt tight. After 1-2 bales the nut has loosened up 2-3 turns. So I have to stop and tighten it back up. If I don't the nut will come off. I am using the correct NH bolts. The nuts are lock nuts so I can't see how they can work completely off the bolt. Anybody ever had this problem before or know what is wrong. Thanks for any help.
JK MN
06-01-2000 08:48:33
 Re: NH 268 Small Square Baler in reply to dave(ne), 06-01-2000 07:52:44
dave, Take the flywheel off and replace the bushing. Bushing is worn enough to let the flywheel wobble a little on the shaft.
dave(ne)
06-05-2000 07:40:01
 Re: Re: NH 268 Small Square Baler in reply to JK MN, 06-01-2000 08:48:33
Thanks JK MN for the info. I talked to a baler mechanic at the local FNH dealer and he told me to try and double nut the shear bolt. I tried that and the nuts still work loose but not as often. So I bought the flywheel bushing and put it in but have not tried it out yet. The flywheel did have a slight wobble before replacing and has about the same wobble after replacing the bushing so now I don't know if it did any good. Is it possible that the gear box shaft is worn? Also I noticed that the shear bolt hole is not round anymore it is kind of oblong. Could this cause the shear bolt to work loose? Thanks for any more help.
