NH HAYLINER 68
Old Henry
06-01-2000 04:10:07
Just bought a used NH68 and am new to baling.
Need to know how to thread the baler twine. It already has twine from the spool thru the needles.
Is up thru the knotters next? Heres were I get lost. The machine was used last year and seems to be in pretty good shape. Anything special to look out for? Thanks. Great site. I've learned alot about equipment & my Ford 640.
Micheal
06-01-2000 06:26:43
 Re: NH HAYLINER 68 in reply to Old Henry, 06-01-2000 04:10:07
just bought our NH 68 end of last year, also. Make sure that the twine goes through the ceramic guides under the plate below the needles. If it is through the needles already, tie off the loose ends to something handy (behind the needles), pull the tie trip rod up, right above the bale chamber and go up and turn the flywheel through several revolutions to make the baler go through its tying cycle. Once the needles come back to home, the twine should be threaded through the knotters correctly and all should be good. Make sure the knots did not hang on the bill-hooks.
get your self a manuel for the baler. There are a lot of adjustments that need to be right to make it work good. once you get it set, it should do you fine.
if you need more info, email me.
micheal
paul
06-01-2000 14:34:59
 Re: Re: NH HAYLINER 68 in reply to Micheal, 06-01-2000 06:26:43
Good advise. Basically if you have the twine through the needles correctly and the twine tied off somewhere, it will go through it's cycle & set itself up, you don't actually get the twine up to through the knotters manually.
The maunal is an excellent idea, that longer chain on the left side of the machine is carefully timed out. If the chain breaks, you MUST get it timed right again or the baler with snap off your needles. Voice of experience there... Many other adjustments & so forth, the manual is a good investment.
--->Paul
Fuzz
06-13-2007 21:48:50
 Re: Re: Re: NH HAYLINER 68 in reply to paul, 06-01-2000 14:34:59
Hi, I was wondering how much you had to give for your 68? Thanks, fuzz
