JD 4 row planter depth adjustment
Newbie
05-31-2000 12:22:44
Hate ot ask dumb question but how do set planting depth?
Mudcat49
05-31-2000 17:41:07
 Re: JD 4 row planter depth adjustment in reply to Newbie, 05-31-2000 12:22:44
What model JD planter? 3 point or pull type?
Newbie
06-01-2000 05:31:16
 Re: Re: JD 4 row planter depth adjustment in reply to Mudcat49, 05-31-2000 17:41:07
Don't know model #. Pull type.
Mike Aylward
06-01-2000 17:54:31
 Re: Re: Re: JD 4 row planter depth adjustment in reply to Newbie, 06-01-2000 05:31:16
Newbie, do your individual planter units lift with a chain for each row, or does the whole frame lift all the row units at the same time? Or perhaps another way, is your hitch a couple of flat irons, a pipe, or a couple of formed panels? If you can tell us any of this, we can likely tell you what you have. As soon as you know the model number, you need to go to John Deere and get a manual for it before you use it. We'll try to help you if you can give us just a little more info. Mike
paul
06-01-2000 14:27:21
You seem to be making this difficult. :)
Would you like to know the model number? I would if it were mine, to look for parts, etc.
How about giving us a better description of what you have. Is it really old, or just kind of old? What kind of press wheels does it have, steel, rubber, etc.? Plates I would assume, or? any attachments like fertilizer, herb/insecticide, check wire, what? Disk openers???
John Deere put a plate or sticker with a serial number on nearly everything they've built. Sometimes it's under an inch of grease, or buried on a rear brace, but with that info we can tell you what you have & how to adjust it.
It's just kinda hard to help you, when you're not telling us what you have. JD made quite a few different 4 row planters, we need more info to help you out.
--->Paul
Dick L
05-31-2000 14:02:23
I don't know about a JD 4 row but My white 6 row is set with the packer wheels behind and under the boxes.
