Wheels for a No. 52 JD two bottom plow
TAZ
05-31-2000 09:23:23
I need a set of wheels for a #52 JD plow. They have a large center hub like a tricycle tractor and have three cap screws holding them in place. They are flat spoked. They did not have a number on them. Can anyone help? Thanks
Bob
06-03-2000 18:32:51
 Re: wheels for a No. 52 JD two bottom plow in reply to TAZ, 05-31-2000 09:23:23
TAZ, Just for your information, the no. 52 plow came with several different wheels, including wheels for rubber tires. If you are looking for steel wheels they did in fact have a number stamped on the inside of the rim (steel "tire") the land wheel is usually a JD1352A or if it was sold for rice plowing a JD1353A which would be 5" wide vs. 4" for the 1352 wheel. The furrow wheel is number JD1311A or JD1300A for rice. Usually the "JD" and the "A" were not stamped in the wheel and often the numbers are hard to see unless the wheel is sandblasted or in good shape. I can't part with any I have but this might help you get the right wheel the first time, good luck. Bob
