Square v Round hole disc
dutch
05-31-2000 06:28:22
I just acquired two sets of discs for my garden tractor.
On the one set the discs have round center holes that mount on a round bar. Each disc can turn independent of the others.
The discs on the other set have square center holes that mount on a square bar. If one disc turns, all discs on that bar turn.
Is the function of these two sets the same? Which is better?
paul
05-31-2000 07:04:18
 Re: Square v Round hole disc in reply to dutch, 05-31-2000 06:28:22
Your shaft nuts are loose. You will have extreme wear with either type. Get those big nuts tightened up as soon as possible. The shaft should be so tight all disks are clamped into one unit. It will take a whole day of tightening, disking, tightening, etc. to get them good & solid. Square or round isn't important, good & tight is.
--->Paul
