Plows
Bob Almstrom
01-15-1999 15:05:53
Hi:
I would like to know what type of plows would work the best for my Farmall Super "C". Would I use a pull type from the draw bar on wheels? or would I use my after market (3) point hitch and pull them from there? Thanks! any help will be appreciated!
Bob
john d.
01-17-1999 12:15:28
 Re: plows in reply to Bob Almstrom, 01-15-1999 15:05:53
Depends on conditions.... If you're plowing gardens and other small patches, the mounted plow is far superior! A SuperC can handle a 2-12 or maybe a 2-14 mounted plow in most soils. A 2-14 pull type might be a little much under most conditions. You'll gain pulling power with the mounted plow because you'll have more down-force on the rear of the tractor (assuming you have enough hp and a good hydraulic system) and be able to pull it in places where traction is marginal. The pull-type plow (properly adjusted) may provide a little better looking and more evenly plowed field, but it's not as easy to maneuver in tight spaces.
Clyde
01-16-1999 09:47:50
I prefer pull type plows.
