JD sicle bar mower?
Brent
05-25-2000 13:31:18
I have a 7' sicle bar mower that is in need of a pitman arm. I'm not sure what kind it is. It has a lot of numbers all over, maybe you equipment guru's out there can help. It has z-342 XA on top of the chain case: z-425 on the side of the chain case: z-343 and z-414 are on covers. Is it a John Deere?
TomH
05-29-2000 18:23:47
 Re: JD sicle bar mower? in reply to Brent , 05-25-2000 13:31:18
I assume you need a wooden one. Try calling Quality Farm & Country (same as Central Tractor I think). They have pitman mower sticks for most models, if you really don't know what kind it is you can get a blank and cut/drill it to fit (part number 12866-043 only costs about 8 bucks). Might need a couple pieces of sheet metal if that's missing too.
Brent
05-30-2000 11:07:19
 Re: Re: JD sicle bar mower? in reply to TomH, 05-29-2000 18:23:47
what does the sheet metal do?
thanks for the help
sickle
05-26-2000 10:19:39
your sickle is spelled wrong!
brent
05-28-2000 20:06:48
 Re: Re: JD sicle bar mower? in reply to sickle, 05-26-2000 10:19:39
thanks for the helpful info. when I need more help with my spelling I will make sure I ask you.
