JOHN DEERE 2 ROW POTATO PLANTER
Mike
05-24-2000 21:59:12
I HAVE A GREAT OLD PLANTER BUT IT DOES NOT SEEM TO DIG THE FURROWS DEEP ENOUGH, AND AS A RESULT THE REAR DISCS DO NOT COMPLETELY BURY THE SEED POTATOES. THE BOTTOMS WHICH MAKE THE FURROWS SEEM TO BE AT THEIR LOWEST SETTING. ANY SUGGESTIONS?
Jack C. Anderson
05-25-2000 09:45:25
 Re: JOHN DEERE 2 ROW POTATO PLANTER in reply to Mike, 05-24-2000 21:59:12
Mike, first are you hitting hard (unplowed) soil
causing you not to be able to achieve the depth you want? Second can you adjust your disc by rotating them to gain a higher hill to cover the seed pieces? Third, I have access to old potato planter parts catalogs. What model planter do you have? Deere-Hoover, Iron Age, IH, Lockwood, Logan, etc.
Tom from Maine
05-25-2000 17:20:34
 Re: Re: JOHN DEERE 2 ROW POTATO PLANTER in reply to Jack C. Anderson, 05-25-2000 09:45:25
Sounds to me like the ground isn't worked enough or that your pole is lowlifting the back end up
the planter needs to be level. you only have one axle
