JD 290 Planter
Jeff U
04-28-2000 04:55:24
Quick question can this planter be used without the wire check? Also are the planter plates still available?
Thanks Jeff
Trace
04-28-2000 19:31:09
 Re: JD 290 Planter in reply to Jeff U, 04-28-2000 04:55:24
Yes, the JD 290 planter can be used without the check wire. I don't know about the plates
phil
04-28-2000 18:53:45
what does this planter look like is it a 2 row i have one and not sure the model mine is a 2 row and has spoked wheels thanks
DCotton
04-28-2000 12:24:37
The planter I have ( a 290 ) does not have the check option and in the book ( still available from JD ( parts and Ops) you can plant in the drill mode. Plates are avail from JD and some other suppliers. I got a pumpkin plate the other day for my planter and going to order some sorghum plates in the near future. I got a bunch of plates with the planter.
Hope this helps
Dennis
