Rotary Mower Question
RAD
04-26-2000 20:10:00
Need recommendation or advice on a 1993, 5ft, 3 pt. rotary cutter called "Field General" manufactured by Taylor/Pittsburg in Athens, TN. How does this type measure up to other brands of mowers?
SCOTT
04-27-2000 13:56:33
 Re: Rotary Mower Question in reply to RAD, 04-26-2000 20:10:00
RAD,
IT DEPENDS HOW BEAT-UP THE CUTTER IS. YOU CAN BUY NEW LIGHT DUTY 5' CUTTERS FOR UNDER 600.00.
WHAT TRACTOR DO YOU PLAN TO USE AND WHAT DO YOU PLAN TO CUT?
LET ME KNOW AND WE'LL GO FROM THERE.
RAD
04-28-2000 07:35:59
 Re: Re: Rotary Mower Question in reply to SCOTT, 04-27-2000 13:56:33
I have a Massey-Ferguson 135 Diesel and 40 acres of overgrown pasture & brush to cut. I have heard good things about KingKutter but never anything about the "Field General". So, yes I need to decide which one to keep. Field General is much newer but may be lighter. Can't find any specs on this model. Thanks for your input.
SCOTT
04-27-2000 14:01:22
RAD,
IF YOUR DICIDING IF YOU SHOULD KEEP THIS UNIT OR THE OTHER UNIT YOU BOUGHT KEEP THE PITTSBURG UNIT.
