JD rotary cutter
haystack
05-21-2008 06:11:46
I have a 5" JD brush cutter, Model 127 with serial # 002. Was cleaning up to sell with a Ford tractor when discovered ID tag. Cutter is used. Question is, is it worth restoring being the low serial number,or save the expense and let go with the tractor. Any help appreciated. Any info. or where to look for advise.The cutter is 3 point and made in Canada. Thank You.
MoMark
05-21-2008 10:05:47
 Re: JD rotary cutter in reply to haystack, 05-21-2008 06:11:46
I also have a 127 & a 227, both serial number 001. As stated, this has no special value.
Ole shovel
05-21-2008 06:58:14
That's a series number not a serial number so no special value as many many made with same series number on them.
