Free travel in cutterbar?
MCL
05-20-2008 11:14:39
Working on a 1090 Gehl mower conditioner. Seems to have a lot of up and down free play. How much is too much. Some places have 1/8 inch or more. I know I don't want it too tight but seems like it needs some shims removed or something. And shouldn't the rear wear plates be pretty close too? Same deal. I know it shouldn't be too tight but not too loose. Free travel and vibration is not good for cutterbars.
Allan In NE
05-20-2008 17:01:36
 Re: Free travel in cutterbar? in reply to MCL, 05-20-2008 11:14:39
Slide your sickle clear out and start with the hold down closest to the pitman.
With the sickle out from under it, rap the hold down with a big hammer, slide the sickle back under it and measure until you get about .010" clearance between it and the sickle.
Slide your sickle back in as you go and move right down the line. Hammerin' and testin'. :>)
If the sickle gets to binding, that means that your bar is bent somewhere along the line and that will have to be addressed.
Allan
MCL
05-21-2008 08:37:56
 Re: Free travel in cutterbar? in reply to Allan In NE, 05-20-2008 17:01:36
The holdowns on mine have shims under them. Just a matter of removing/adding shims to get what I need. Deere dealer tried to sell me adjustable ones. Too rich for my blood.
Don-wi
05-20-2008 13:53:32
There should be some clips that hold the top of the sickle down. On ours there is a clip on every-other guard, and they're tight against the top. The wear plates behind the cutter bar just have to still be there. When cutting, the hay will keep the sickle against the wear plates.
Donovan from Wisconsin
