JD 114 Baler
cammy729
05-20-2008 10:01:13
I was wondering if anyone knew where i could find wire for my 114 Baler, its not just your run of the mill wire its a specific type and is in cylinder like spools if anyone has any more info. or specs. on it plesase let me know -Thank you
Tx Jim
05-21-2008 04:21:59
 Re: JD 114 Baler in reply to Bishgrg, 05-20-2008 10:01:13
cammy,
Why couldn't you build a larger wire box and use the available rolls of baling wire as they are?
Leroy
05-20-2008 17:27:10
 Re: JD 114 Baler in reply to cammy729, 05-20-2008 10:01:13
If you can go back in the archives a couple of years there was a address of someone that is taking the new modern size rolls and rerolling it down to your size roll. Check on this forem and also the JD forem on this site. It will take a lot of time but the information is there.
