Landscape/Stick Rake Size
Kevin in OK
05-18-2008 20:38:21
I think we will go ahead and get a plain old landscape rake to try to pick up sticks... question is, how big of a landscape rake can I pull with a Ford 8N (25 hp, 2500lbs) or a Ford 631 (32 hp, 3000lbs)? The more I think about it, it seems like either could pull an 8' rake, however I thought I'd get a second opinion.
I know that either will lift up to an 8' rake, however I don't know how well it would actually work picking up sticks. Any other thoughts are appreciated. Thanks
Kevin
johns48jdb
05-19-2008 05:11:02
 Re: Landscape/Stick Rake Size in reply to Kevin in OK, 05-18-2008 20:38:21
don't pile the limbs up very high. once you try dumping them and driving out you'll see why. sometimes its best to pull them where you want them dump and back out over them. going slow and not giving the tractor much gas will work better than going full bore at the job. i bought a rake like your talking about from a ford dealer and you could buy a landscaping blade to mount to the same frame. don't remember how much trouble it would have been to do it, but you might look at that if your interested. i made an old heavy junky looking limb rake out of some 3 inches channel and some angle iron. i only had 4 "legs" sticking down out of the 3 inch angle. i sharpened the end to where they would dig ina little bit and be less like to hit and ride up over a limb. it was big and heavy on purpose to hold it down and not ride up over stuff.i made it real deep so it could really rake up a pile of big limbs. i'd use it first to get the big stuff and then change to the little one to clean up.
fergienewbee
05-19-2008 01:15:10
I rented a six footer to rake up dewbery canes. They send out several runners along the ground. It really filled up with stems and had to be cleaned after each pass. I also tried it to remove duff from an old field. It didn't work all that well. You might rent one first to see how it works for you. I decided if I wanted one it wouldn't be at the top of my list.
Larry in Michigan
paul
05-19-2008 00:14:06
What is the work involved here? Many sticks in a small crowded, treed area - smaller rake would be more manuverable.
Few sticks, wide open areas - big rake gets done faster.
Don't expect perfect results. Take a leaf rake and drag it across the lawn - it works good for a few feet, then fills up & spills leaves ubder it. Works longer in thin leaves, fills up fast in thick leaves.
This is how the landscape rake will work for twigs & small branches.
Longer branches tend to kinda bunch up & rattle along.
I have a 6 foot rake on my 27 hp compact tractor. Works great to groom the driveway, and I can really clean up parts of the grove with deep leaves & small trigs. Make piles of the junk and can scoop them up with the loader.
An 8 foot rake would work sometimes with the tractor, but other times would be harder to manuver in the grove. I can make it pull pretty hard with the 6 foot when I gather a real pile of debris, or heavier work on the driveway.
Tough call.
--->Paul
Kevin in OK
05-19-2008 05:47:17
 Re: Landscape/Stick Rake Size in reply to paul, 05-19-2008 00:14:06
It will be primarily to rake up sticks and branches in a small pecan grove that are too big to be brush hogged.
You make a good point about maneuverability, but we are in the process of thinning the orchard right now, taking the trees out to 80' spacing. We are a third to halfway done with that project, so maneuverability shouldn't be a major concern within the next year or two.
I suppose we could rent first, just to see how well it works.
Kevin
