J.D. 327 baler -
mud
05-14-2008 18:16:18
What is a fair asking price for a John Deere 327 baler in very nice condition?
Also, what are the pros and cons on theses machines?
Can they produce a smaller bale, say 40 lbs.?
Thanks for your input. mud
burnetma
05-16-2008 11:36:17
 Re: J.D. 327 baler - in reply to mud, 05-14-2008 18:16:18
I didn"t completely answer your question.
Pros:
Very good low-mid capacity baler.
Knotter assembly identical to other JD square balers.
Makes nice shaped & consistent bales.
Less sensitive to windrow consistency compared to other brands.
Built to last a lifetime for a small family operation.
Simple operation and maintenance.
JD parts and publication availability.
Cons:
Limited capacity
Pick-up width is narrower than other models, but this is minor
If the machine is in decent condition and has not been beat into submission, it will make you an excellent baler.
This will be my third year baling with this machine and for my small operation, the JD 327 is perfect.
I hope this is helpful.
Joe in IN
05-15-2008 06:21:41
Saw one sell at auction this spring for #3500..no thrower. Used by local School FFA to bale straw. It was in very good condition. Very little worn paint.
I also have a 327, great baler. Wouldn"t think of trading it for another....
Con would be capacity if doing high volume. I only do 20 acres so not a big deal, probably not what you want if baling 200 acres, but it is plenty fast enough for me...
First cutting with good windrows I can get 4 bales(55lbs) a minute, about 1 every 15 seconds. Most of time it"s just me stacking so we don"t go that fast as I wear out. If there are 2 of us stacking we do.... So it can crank them out, just not like a 348....
burnetma
05-14-2008 20:45:16
I am not sure what is fair today. I gave $4000 for a low use 327 with 40 pan thrower 3 years ago. Still had paint on nearly all of the surfaces. It does a fine job.
You can adjust the length of the bales to get any weight you want if you are not using a pan thrower. You can also loosen the bale to reduce weight. The pan thrower will toss a loose bale into a wagon without it exploding, but it just can not be too loose.
