Plant Peas with a JD 1240 Corn Planter?
Faber McMullen
05-13-2008 20:27:04
Does anyone know if it is possible to plant purple hulled peas or black eyed peas (you northerners may not know what these are) with a John Deere 1240 corn planter? I'm not sure what to use to plant peas.
Thanks
F McMullen
Texas
NW MO Poppers
05-14-2008 13:57:45
 Re: Plant Peas with a JD 1240 Corn Planter? in reply to Faber McMullen, 05-13-2008 20:27:04
If you can come up with a plate that will fit half way decent, then the 1240 will work great. Grandpa used a 494A and then a 1240 to plant peas. Not sure what plate he used.
Leroy
05-14-2008 05:03:27
Is yours the plate type planter? If it is the special John Deere Plate book will tell you what plate to use for them. If the planter is plateless then I do not know about them.
Leroy
05-14-2008 05:06:26
 Re: Plant Peas with a JD 1240 Corn Planter? in reply to Leroy, 05-14-2008 05:03:27
I should have added that that plate book lists several hundred different plates for the plate planters and for each it cives size of cell, type of cell and what the plate is designed for. from 4 cell to 60 cell plates.
Too Far Gone
05-13-2008 20:38:37
I set my 1250 same as for soybeans and had decent luck
