Rotary Hoe
mark
05-13-2008 18:06:45
I have never used a rotary hoe and I wonder how high the corn can be and furthermore..... how does the hoe take out weeds and not the corn as well?
johns48jdb
05-14-2008 06:19:41
 Re: Rotary Hoe in reply to mark, 05-13-2008 18:06:45
just as a bit of info - jd made a hoe that actually mounted on the cultivators for the 200 series cultivators that i know of. it only has 4 wheels for each row and was used like a fender to protect to much dirt from being thrown by the sweeps as well as loosing the dirt around new plants and as a weeder in the actual row. i have a set that cost me a bundle several years ago. they have never been used that i can tell, but they are painted green. i can remember a neighbor using them on his tractor and his were painted yellow. we were driving along beside of him on a road as he was cultivating in the bright afternood sun and i can remember how pretty i thought the b jd tractor and those spinning yellow hoes were.
rednekelmo
05-14-2008 05:07:51
you guys must live in rock free areas no one mentioned the thrill of a rock wizzing by your head.there are a few in barns around here that come out every few years to break up the crust when when we get a heavy rain and then some hot sun to bake the ground befor the corn or beans can get out
Allan In NE
05-14-2008 05:30:22
 Re: Rotary Hoe in reply to rednekelmo, 05-14-2008 05:07:51
Gotta really be careful in beans.
If that plant is in the crook just under the surface, the hoe will snap 'em off like a matchstick and ya can do more harm than good.
But yes, corn can't break thru the crust like a bean can, so ya hoe the fire outta 'em. :>)
Allan
Stan - Florida
05-14-2008 04:44:01
And the best part of a rotary hoe is that you can use it as fast as your tractor will pull it (within reason). I used to run in 5th gear with our '43 John Deere 'B' pulling one. Great fun for a teenager.
Stan
Gary,kansas
05-13-2008 21:36:21
Good instruction here, the hoe is the best friend of the farmer that uses the minimal amount or no chemicals. Along with keeping the ground from blowing, a properly set hoe can be used weekly after planting until the corn has reached the 2-3 leaf stage. Speed is the key, we used to put those I.H. tractors in 5th gear as fast as we could ride her, torque back and throttle back on the ends and kick out those little white weed sprouts by the millions every day. I used to increase my plant population by 10% to offset any hoe or cultivator loss. Remember, a driver sets it by the book, an operator sets it to do the best job! Good Luck.
James Howell
05-13-2008 19:07:42
The rotary hoe is a very unique implement.
There are several articles on using a rotary hoe as a "mechanical weeder" on the web.
Search the web via Google on rotary hoes; there are several interesting articles.
I have a 7'(2 gang) and a 14'(4 gang) #14 rotary hoe.
third party image
Both will be used to "aerate" my pastures.
As Allen mentioned, they will also "pluck" small weeds from plowed/disked ground when pulled forward.
They can also be used as a "packer" when pulled backward.
third party image
When transporting on the public right-of-way always pull backward; otherwise you pick up every plastic Walmart bag, Bud Lite paper 6-pack, and KFC meal sack.
Just finished "restoring" the 7' last weekend with the JD decals on the back. No picture since Nancy"s computer is in the shop.
Hope this helps.
Allan In NE
05-14-2008 04:07:44
 Re: Rotary Hoe in reply to James Howell, 05-13-2008 19:07:42
Out in this windy country, ya don't row crop without a hoe. Wind will pick up that soil and use it like a razor to cut off a new crop.
These are set up for beets.
Allan
third party image
mark
05-14-2008 05:11:19
 Re: Rotary Hoe in reply to Allan In NE, 05-14-2008 04:07:44
My hat is off (my bald head) to you fellers for all the information. Now, I"ll have to find myself a RH and give it a try.
James, it appears the small one spent a few years in the fence row before you rescued it! Are you in the Carolina"s? Those pines look typical of that area.
With the public becoming so anti-chemical these days, I suppose we may see a resurgence of mechanical cultivation to some degree. I know it requires more time, more fuel, more everything and how the heck it could be done (it won"t) when a man has 6,000 acres planted is beyond me. I just wonder what the Yuppie Chicken Little"s in Foggy Bottom who make policy, are going to do when crop production fails to meet demands after they have outlawed chemical fertilizers, herbicides and pesticides.
James Howell
05-14-2008 10:18:12
 Re: Rotary Hoe in reply to mark, 05-14-2008 05:11:19
Our farm is located in NE Texas near Mt. Pleasant, TX on I30.
Grandaddy Howell bought this farm back in the early 1920's. At that time all of it was a cotton farm. He was a cotton farmer and ran the boiler at the cotton gin.
The 7' rotary hoe was bought in nearby Pittsburg, TX from an older gentleman that buys and sells used farm equipment.
Most equipment I buy from him is uglier than my step mother, but still functional after a lot of work.
I will post the 'restored' photo next week when Nancy gets her computer back from the shop.
E.B. Haymakin'
05-13-2008 19:34:47
Is that a Miller Tilt Top trailer that rotary hoe is sitting on? Have you had any problems finding tire shops to change out the tires?
Leroy
05-14-2008 04:59:27
 Re: Rotary Hoe in reply to E.B. Haymakin', 05-13-2008 19:34:47
That looks like a John Deere dealers tractor hauling trailer of the 30's & 40's and built by Deere
James Howell
05-14-2008 10:32:05
 Re: Rotary Hoe in reply to Leroy, 05-14-2008 04:59:27
You are exactly right - a John Deere #16 Delivery Trailer.
third party image
It is being 'spruced up' right now. It will eventually become barn art and be rolled out for hay rides at annual 'get togethers' at the farm.
No problem with the tires being mounted.
third party image
I do enough business with the tire shop that they look forward to some of the challenges that I bring by.
I was hoping someone would notice the trailer. Thanks for asking.
Allan In NE
05-13-2008 18:22:42
The only time it really works as a "weeder" is when the corn/bean crop is at the 2 leaf stage and the weeds are about the size of a nat, just emerging. Tiny.
The bigger the crop, the more the damage. Shouldn't be used past the 2 to 3 leaf stage.
It picks "chunks/clods" of the soil and will take out some of the crop as well, but since the corn/bean is a bigger plant, it has more effect on the smaller, baby weeds.
"Here", it is only used as a tool to rough up the ground after a hard rain to keep it from blowing, not as an "anti-weed" implement at all.
Allan
mark
05-13-2008 18:27:50
 Re: Rotary Hoe in reply to Allan In NE, 05-13-2008 18:22:42
Allen,
I can't say I ever seen one used here in eastern KY, although I am sure somebody has. I have looked at auctions and couldn't help but wonder, how the hell the contraption works.
