What to do once plunger is out???
reid5365
05-13-2008 13:55:33
Ive got a massey 12 baler that i pulled the plunger on. Didnt loosen rails or mess with shims at all. It wasnt rusted in too bad just enough to where the flywheel wouldnt turn. Clean up the rails real good, coat with grease and put the plunger back in??? What do I do now? Thanks Guys!
tedbo
05-19-2008 20:56:05
 Re: What to do once plunger is out??? in reply to reid5365, 05-13-2008 13:55:33
Hi all! I have a model 12 that I am getting up and running.
I got it and had a guy work on it and had a problem with banana bales.
I'm new to baling and know little about this massey.
I got the service manual and the operator's manual recently.My plunger was stuck real good when I got it and am in the process of rebuilding it with another massey for parts.
Mine is out and I have cleaned up the rust. I am now re-shimming. My question is this- I don't recollect seeing where to use grease and what kind of grease on the runners.
I thought that you couldn't use grease as it would contaminate the hay. Spray on graphite maybe?
Sorry to be so long winded. Thank you for the input!
tedbo
05-21-2008 05:18:35
 Re: What to do once plunger is out??? in reply to tedbo, 05-19-2008 20:56:05
Well,looking at what I posted, I may not have been as clear as I wished to be.
At this point I have found out that my ram knife was bent inward near the bottom. I think someone who had it before me must have caught a rock,t-post or large stick.
I have sharpened both knives and shimmed them square. I think this was the reason for banana bales.
I am taking parts off of a junked massey. I put the best ram bumpers,rails and shims between the two of them and put them on my good baler after a thorough cleaning.
I am still curious to know about the greasing part. I will need to replace the bearing where the ram pushbar attaches to the gearbox. I took off the snap ring. I don't know the best way to get it off to replace it. Thanks,all ahead of time!
ebbsspeed
05-13-2008 14:35:33
Find a windrow somewhere.....
Michael Soldan
05-13-2008 15:06:38
 Re: What to do once plunger is out??? in reply to ebbsspeed, 05-13-2008 14:35:33
I agree, put the windrow to it and make it work 'til she is shining!
reid5365
05-13-2008 17:42:25
 Re: What to do once plunger is out??? in reply to Michael Soldan, 05-13-2008 15:06:38
But seriously can i just put it back in after the rails are all clean and greased up and go to work??
Michael Soldan
05-14-2008 04:21:31
 Re: What to do once plunger is out??? in reply to reid5365, 05-13-2008 17:42:25
I have a Massey#10, we left a wet bale in the chamber..had one heck of a time getting the plunger to move, finally it moved, cleaned out the chamber and went to the field where the hay was just right and started baling, after a 100 or so bales I put some grease on the rails and then continued baling
garytomaszewski
05-13-2008 18:55:01
Reid, if all the rest is ready, the guys are right run something through it. Get a couple,3-4 bales of straw feed them thru CAREFULLY, take from the chute feed them thru again and again. Straw is drier and more abrasive and will clean rust in bale chamber. Be very careful, but this way you can check operation before you need it to work.
