I have been plowing since 1970
RickB
05-11-2008 12:14:07
How far above the share you set the coulter is a function of plow depth, coulter diameter, whether it is spring loaded or on a fixed shank and how deep you need to run the coulter to cut the crop or residue. It is a field adjustment that should take into account most or all of these variables. The fore and aft adjustment is dependent on how much trash clearance you need. Further forward can lead to trash plugging problems between the coulter and next bottom forward on older plows with little rake clearance. Further back can lead to plugging on the coulter's own bottom.
