kuhn mower
Johnfl
05-11-2008 09:01:32
A friend of mine was mowing the other day with a 9ft kuhn mower and the whole thing locked up broke the pto shaft and everything ,said it started banging few min. before it seized up. I belive its and older mower any one have any idea on where to look first,and a good source for parts . thanks for any help John
KEH
05-11-2008 15:41:47
 Re: kuhn mower in reply to Johnfl, 05-11-2008 09:01:32
Agree with the other 3 posters. What can happen is that the oil seal in the gear box leaks oil into the cutterbar. Too much oil in the cutterbar can make it lock up. Obviously, if oil is not added to gearbox it will tear up. Buying a new cutterbar or gearbox is often cheaper than buying new parts and spending time repairing. New cutterbar is probably over $3500. New gearbox probably $1500 or more. Your friend may want to take it apart and see what tore up.
Repair costs are why so many disc mowers are junked.
KEH
reid5365
05-11-2008 10:46:27
Youre probably better off just buying a used one. Parts for those can get pricy depending on how many you need. The bearings failed in the cutterbar and then the internals of the cutterbar destroyed themselves. Tell your friend to listen to his equipment and next time it starts makin funny noises to shut it down and diagnose the problem. Proper maintance would be a good thing on the next disc mower he gets too.
kyhayman
05-11-2008 10:38:01
Sounds like a bearing failure internal in the cutter bar followed by catastrophic cutterbar failure.
gwiz
05-11-2008 09:49:28
Tell your friend next time a machine starts banging to shut it down.
You can buy those used for around $2000; probably cheaper to just buy another one. If you are just talking about the disc mower, Kuhn also made them for NH, Deere and others. All parts will be the same. James
